Sway Bar Bushings + Endlinks
kangarooboy
After the cylinder head rebuild and the all new exhaust system I can't afford to go to all new sway bars quite yet. So I'm refreshing the stock bars. The stock rubber endlinks and frame bushings are shot, barely hanging on in the front. I like the poly endlinks and will get a set of those for front and rear, but is there a poly option for the frame bushings? The clips look okay but should I think about replacing them? Part numbers would be a big help.
Also, if anybody is selling a used set of swaybars, please let me know. :)
Thanks.
Brenden
1974 2002
Mit rost
2001 325i
I was in the same position.
With the stock swaybars, I ended up using the stock rubber frame bushings and polyU end links. The ride is fine for me with that setup.
Steve J
& too many bikes
call ireland engineering. i got my front frame urethane bushings from them. just make sure you know the diameter of your sway bar before your call or they won't be able to help. they had them in stock when i called earlier this year, but i thought someone said they were out of stock for a while.
Phone: (626) 359-7674
'74 turkis 2002ti(-i)
i've got a set of 19/19s that i just bought from a fellow FAQer.
i'll let them go for what I paid, $100 shipped (I've decided to go w/ the IE 22/19s)
Don't know the brand and you'll need to still get bushings.
PM me if interesed.
Colin K.
Malaga '72 tii
