jpitma1
15x7 panasports
3 posts / 899 viewsLast Reply
I found some 15x7 panasports et 30 4x100. Will these fit with a stock suspention/fender lip? What size tire is best? Thanks
Oh, God, no way that those will work-
box 'em up and send them to me right away!
Don't go any bigger than a 195-50-15-
anything larger in diameter will hit the firewall badly,
and anything taller or wider will run into the struts or the fenders...
That said, you might end up needing 5mm or 10mm so of spacer DEPENDING on
the tires you use- I have Bridstone S03's on a 26m backspace, and I run 1/4" (3mm) of spacer for good luck...
Nice find!
Toby
The 3-5mm spacer might be an idea, dependant on your tyre choice (some tyres have wheel lip protectors built in and bulge wider than those with out, and possibly hit the struts). You may find the stick out beyond the guards 1/2" - 3/4" but that may vary too. Nice find indeed. Beaner7102
