Late model seat belts...
Meintii
I have an early model (72) tii and I need to know if anybody has used the seat belts from the late in an early? I need to used to back and front seat belts and would like to get around drilling holes in my baby!!
Zac Cardinal
1972 2002tii's Blog
1976 2002 "Margie"s blog
I've got 'em. For the fronts, the newer reel has a locating pin that keeps the reel in position. The best way to use that is to carefully locate and drill that hole in the body. Carl Nelson and other '02 parts specialists can get you the belts.
Curt Ingraham
1972 2002tii, 1976 2002
Improved 2002 Radiators
all the little washers and spacers that go with the belts, and note how they are installed. And be sure the inertia reel is installed perfectly verical, or it'll lock up whenever you try to use it.
Have fun
The rear retractable belts (lap only) use the same mount points as the old Klippan style, but the bottom seat cushions on the later cars have a relief cut the earlier ones lack, so you might have to "finesse" (gently cram?) the seat in a little. Oh, and the bolts are inch-size, not metric if you buy new.
'73 2002tii Agave green #2763558
