philv
alternator upgrade.
4 posts / 1313 viewsLast Reply
is the 320i alternator the only one to use? cant find anything by searching
the site.
you can use an alternator from 533 on 528e, but you will need to use an upper mount from that engine too and a couple washers as spacers. Otherwise the installation just like in the FAQ
steve k.
Search AL41X. I recently upgraded to this model. It is 65amp internally regulated off a 5 series. I had to grind down the shaft a bit to make clearance for the fan, and I had to use a combination of pulleys and washers to align correctly. Curt Ingraham was nice enough to let me use parts off of some extra alternators he had, hopefully you have a parts place near by if you decide to go this route. Then follow the faq for the small wiring change.
