KimiP
M10 Valve Cover Painting
8 posts / 1919 viewsLast Reply
Hi guys,
I'm a new member and need your guys help on how to make my M10 valve cover looks new and nice!
thanks alot,
KimiP
Hi guys,
thanks alot,
KimiP
it's really very simple...clean it very well...no grease
buy a can of your favorite paint in you choice of color then push the button
how about bead blasted and then paint?
that'll work...but isn't necessary
Is there any risk of the bead blasting causing distortion of the valve cover?
Also, I presume you are suggesting leaving it in its natural state after blasting it... or is there a polish or protective coating required as well??
Also, I presume you are suggestion leaving it in its natural state after blasting it... or is there a polish or protective coating required as well??
blasting won't distort or harm the valve cover unless you have an idiot, that's never used a blasting gun shoot it
if you take the time and expense to blast it, then you should mosdef seal it because it will very soon, again go to hell in a handbasket....
google glistenpc...very good stuff and can be brushed on, no special equipment is needed..it's the only thing i've ever used that's still sticking to the aluminum
I am in the process of painting mine. I used Aircraft remover to remove the old paint and WOW it does an awesome job at removing the toughest paint very very easily. I used Dico buffing compound on the billet and BMW part and that brought the aluminum to a shine. Tape that off and paint the rest using VHT Enamel paint in the same color as the car.
