interior signal flasher miscue
Armond
when I turn right it flashes once or twice then it disappears. Left is o.k. checked the tail lights and both signals lights work but the interior light when I make a right does not. What gives?
73 Tii A4 BOD Oct. 13,1972
74 Tii BOD Nov. 16,1973
FAQ Member 1683
Mario Andretti
Check the contacts on the bulb sockets in the rear taillight. You can pull the bulb and clean the center contact. While you're there, bend the contact toward the bulb to make a more positive contact. Also clean the socket with a Scotchbrite pad. On the front indicators, the phillips screws are grounds so make sure the holes they screw into are'nt rusty.
BTW, check ALL your bulbs to make sure they're of the stainless base variety. Sylvania/Osram market a complete line of European bulbs with the proper wattage at your local parts house. These bulbs fit the sockets much better and are more resistant to corrosion. BMW marks each socket with the proper wattage so it's pretty mistake proof. It also makes it easy to make a list for quantities.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
