Front subframe repair idea- opinions please/ pulling the sub
peteinjp
So- as I knew it would when I installed it- the front sub left motor mount arm has cracked. As A repair idea I am thinking of getting the arm cut off of a junk subframe, splitting that arm up the center and fitting the 2 pieces over the existing one- with the empahasis on fitting. I just thought it might be a clean way to go about getting a full length reinforcement.
Also in terms of pulling the sub with the motor in- better to unbolt the steering box or pull the pitman arm? I have a ball joint splitter so I could try that out but I do not wont to screw up the boots at all.
I just did this repair.
Here is the write up I did withe pictures.
http://www.bmw2002faq.com/component/option,com_forum/Itemid,57/page,viewtopic/t,279528/
The broken part was welded back on.
for pitman arm I used the method of hammering both sides of the arm and the ball joint just pops out.
e-mail me if you have any questions.
Ray,  Current BMWs, 1973 BMW 2002, Turkis, and 1997 BMW 318i 5sp avus blue.  Drove a lot and sold over the years, in reverse chron.
     1997 m3 coupe silver, 1998 318ti red, 1996 318ti red,
     1973 2002 Agave, 1971 2002  GM brown
if you choose to repair the crack make sure to drill out the base of the crack. Seriously take a drill bit and drill a hole at the base of the crack. If you don't and just weld the crack will keep growing. Drilling is the only way to stop it. Afterwards it can be welded up and painted so you'll never know!
HTH,
TJW
E36
