wake74
Timing Setting
3 posts / 907 viewsLast Reply
Probably a dumb question, but I'm running a mechanical distributor off a tii (I believe). I need to time off the timing mark, and crank pulley not the ball and bellhousing method.
I have the shop manual with the various timing curves and set-points. Do I use the tii curve or the regular 2002 curve?
Thanks,
Glenn
Wrong, use the ball in the flywheel method, and set the revs to 2400rpm at all will be sweet, see attached. Beaner7102
Unfortunately, I do not have a bell housing that has a hole in it, so that option does not work for me. I need to actually dynamically time it with the crank pulley and marker on the timing cover.
Anyone else?
Thanks!
