Quick rear diff question
70roundtail02
On the new 02 the rear diff looks newer and I am trying to figure out if it is an upgraded one. Here are some of the things I got off of it.
In yellow there is 429 written can't tell if there is a dot but that is on the side.
On the bottom some of the casting I could read had a very large raised 88, and in another section GGG
On the tag was stamped 114OA4490.
Any help would be great thanks
Tristan
1970-resto/mod =money drain
1973 Charmonix, mhh clean
GO COUGS
It is a 3.64 ratio open differential. It is not the original differential so yes it was replaced. The prior owner had a differential failure and replaced it with a factory rebuilt unit.
shermanmartinez@hotmail.com
remove the rear cover and count the ring and pinion teeth,
look for the stamped ring gear numbers stating the ratio also, and if a 'can' appearing unit is next to the ring gear - it's a limited slip - which means if you rotate one rear wheel - the other wheel will rotate in the same direction (car on lift). You need to tell us if it's open or limited-slip because the lubricant requirement is different. Better find out.
'64 R27 250cc #383851 18,000m
