Valve stem question (for early factory alloys)
02fanatic
Hey all:
I bought some rubber valve stems for my recently completed early factory alloys (did the repaint myself-not half bad for an amateur), and the rubber stems don't seem to be deep enough for the 10 to 12 mm thickness of the alloy hole in the wheels...they seem to be ok (my '73tii has similar stems), but I wonder if they will hold air adequately.
I am wondering if I should go with metal stems...may look better also. There appears to be enough flat surface area to bring the nut up tight and not leak....I had a leaking problem with the metal stems on my BWA's so I was somewhat leary to go with metal stems again.
Any suggestions?
Any good sourses for valve stems?
I have decided to mount 205/60/13 Sumitomo's on these wheels and mount them on my '76 (not period correct I know), but I love these wheels...the BBS's are always dirty and tough to clean.
Thanks for any help.
John
Mit freundlichen Grüßen
John Weese
'72tii "Hugo"
'73tii "Atlantik"
'74 '02 "Inka"
'76 '02 "Malaga"
'72tii engine VIN 2760081 - waiting on a rebuild
"Keep your revs up and watch your mirrors!"
John,
The alloys look great!!.Please let me know how the 205 Sumis work out.
Thanks
Jonathan
1973 Malaga "ti"2.3 stroker,dual 45s,lots of Alpina content13x6 Superlites bilsteins,Petri Sport ,GTS Seats,Coco Mats,Old Man Style "Patina"....but the old Emily is Fast.
2010 GTI 200 H.P.,dsg ,18"wheels etc.modern daily driver.
John,
There is a tire shop here in D.C called Radial Tire 301-585-2740.Serious PCA,BMWCCA,SCCA sponsers-supporters.I've used them for 20+ years.They are excellant w/ odd and specialized applications.If I can help you source the stems,just let me know.
Jonathan
jgm at starpower dot net
I bought 'em in 1990--replaced 'em (corrosion was forming around them) when I mounted new tires in 1991 and have had no problems since...through several sets of tires.
Ask a tire place, as there are plenty of alloy wheels these days at least as thick as the BMW's...and you won't have to worry about dissimilar metal corrosion with rubber valve stems.
cheers
Thanks Curt & Mike:
But I already ordered 4 stems from Bav Auto ($5.95 each)...maybe I'll clear coat them before I install them for some added protection Mike. I really like the look of the metal stems if they will work ok.
John Weese
'72tii "Hugo"
'73tii "Atlantik"
'74 '02 "Inka"
'76 '02 "Malaga"
