Front brakes pulling right Rebuild Tii calipers?
Armond
Don't forget to adjust the rears, the rears work diagonally opposite to the fronts. If the rears are out of adjustment the fronts will never work correctly. Check them before pulling the caliper. Beaner7102
You can buy them rebuilt. They're pretty inexpensive.
Cris
I'll follow Beaners suggestion but where can you get the Re-build CJ?
73 Tii A4 BOD Oct. 13,1972
74 Tii BOD Nov. 16,1973
FAQ Member 1683
Mario Andretti
Check your local parts suppliers - they should be able to order rebuilt calipers for you. Expect to pay between $40 to $75 per caliper with a core. Even the national parts suppliers like Autozone have rebuilt calipers.
You can also get caliper rebuild kits from the mail order parts suppliers (Bav Auto - etc) but you're probably not going to save much money (It's hard to stomach paying $30+ per side for a couple o-rings and boots).
It's a good time to change your brake lines while you're doing this project!
GregH
