Tranny mounts
i just replaced my tranny mount with the ireland urethane one and wow every thing runs better now no more clunking noise from the tranny slapin the tunnel, the dual webers stay in tuned all the time and idle smoothly now engine note sounds more meaner exspecially at high revs. and just ran an auto cross event yest i believe i spun the tires shiftin to second after leavin the line. and best of all it only took thirty minutes to pull the old one off and put the new one in. i'd highly recomend doin it exspecially if u have dual webers tht don't want to stay tuned for more than a week. now i'm just waitin for some time to put in the urethane motor mounts from ireland.
You may not want all urethane mounts if you value your teeth. All urethane also can cause the LHS mount bracket to fracture. Try just replacing the RHS and leave the LHS in rubber, it will be pleanty stiff. Beaner7102
