Slavs
Have any of you come across this cam. I have one, and it requires lash caps. Lash caps on a 273 ? Along with the "273" the script "RC or So Cal Cams" is also etched into the cam. The engine ran fine with it. Its obviously a regrind, but I've never heard of this cam before.
I'm rebuilding a motor and I'm debating using either this cam or a stock one.
Slavs
The US standard is to measure duration at .050" of lift-
for some very good reasons.
BMW, Schrick, and many of the European companies measure TOTAL duration
at zero lash- so they include the acceleration and decel. ramps of the cam.
Which don't make much power for you.
So your '273' cam actually may have a '316' or '305' total duration.
And probably about 8mm of valve lift- it's hard to get much more than that
on a regrind.
fwiw,
