cold compression numbers- what is ok?
jetboy
So I am no expert at compression so please bear with me.
I have an old engine on a stand - I removed the manifolds, changed the oil and filters, put some Marval M oil in the oil and a bit down each spark plug hole, hooked up a battery.
then did each cylinder down the line: got approximately:
25, 165, 125, 125
But when I went back to the first 25, I got 75 the next time - and it seemd to get better the longer i turned the engine over.
I have some general questions: how many revolutions should you need to get a firm reading? is it wierd that the more revolutions I did the better number i got? the one that got 165 seemed to jump perfectly there and stay, the others took a bit more work.
in any case, it looks like I will have to tear it down. but wanted to see what people have to say about compression tests done this way- if they are reliable or not etc.
'70 project
A cold compression is not really 100% accurate. Hot compression test is the way to go. You could have some carbon build up under a valve in the low cylinder that you have. DO you have a leak down tester? A leak down will tell you if you are loosing air through the rings or through the valves.
69 2002 1668997 "Geboren ein Hölle"
Shhhhhh... Another Whispering Bomb!!
i dont have a leak down tester, I have heard about such a thing, but not sure how one does it or how much its going to set me back.
actually the intake had some white carbon/corrosion build up on that cylinder - and not on any of the others. I cleaned it up as best I could- but maybe it just needs to break in again (I hope)
'70 project
Get the motor running. Once it runs, it will blow out the loose carbon in that funky cylinder and your compression numbers will go up. Try to do a hot compression test and you will see what I am talking about.
