why the e21 323i TO bearing?? what slave hose ext to use?
winstontj
Will a standard E21 320i TO bearing work?
Should I just buy the Aardvark "longer hose" and not ask anymore questions? I have a new metal hose from a 320i and plenty of steel line - but you can't use that right, because of the vibration... So is there a line from a specific car?
Also do I need to change out my Pilot Bearing? Is the needle on the transmisison different between the 4 & 5 gearboxes?
Thanks...
Sorry for all the questions about this. Just trying to make sure I'm not missing anything for tomorrow...
E36
U have to pull the flywheel for that right? press/hammer it out and then stick in the new one? That means new flywheel bolts and PP bolts too then...
E36
you should be able to pull the pilot bearing with the flywheel in... But a with a new clutch you should surface the flywheel.
Also you do need the 323 throw out bearing...it is longer
1985 e28 w/LS1/t56 and a bit more...
1970 2002 w/ m42 swap
-Contact me for m42 mounts or e28 ls1 mounts-
www.classicdaily.net
You nicht needenzie 323 throwout mit der small (215 mm? 220 mm?) klutch. You know, vat comes vit der 320 BMW.
You must havenzie 323 bearingg vit der 228 mm klutch.
Stupid Jaegermeister... must haf more...
