Help - Need front side bushing part numbers
ryanOC
Specifically the 2 different part numbers for the control arm bushings.
Also, how many bushings go on each sway bar link? It looks like there are 4 per side, and then the 2 sway bar bushings towards the front and center
I've already put in the new tie rods, I have ball joints waiting to be put in, but I have to order the bushings first so I can do it all at once.
If anyone can give me a straight answer regarding part #s and quantities, I'd really appreciate it
I've asked before, but became more confused by the responses....
1969 2002 Automatic "Pumpkin"
in the image here #13 points to both the control arm AND the inner bushing.
i'm assuming that has to be a mistake....
i just really need to know the part number for the inner control arm bushing
or whether or not it's the same as the outer bushing...
quick! help!
http://realoem.com/bmw/showparts.do?model=ST12&mospid=47140&btnr=31_0436&hg=31&fg=05&hl=17
No mistake, # 13 is the control arm with bushings, # 14 is the bushing itself.
Here you go.
Control Arm Bushing - Inner
Part # : 31 12 2 614 100
Control Arm Bushing - Outer
Part # : 31 12 1 112 902
Compliance Bushing Radius Rod
Part # : 31 13 1 108 373
The sway bar link at each end of the bar consists of 4 bushings, 4 washers, a bolt, nut and a spacer sleeve.
Bavauto sells it as 1 part # SBH KIT, it's easier that way.
Hope this helps.
