quick wiring question
Hugh
I got a couple of those round dash button switches from a 320i (a green one and a purple one) at the junkyard this weekend. I used one to wire up the manual overide for my elec cooling fan.
Question: How does the wiring work for the switch to light up?
There is 1 green wire (I wired it to power)
There is 1 black wire (I wired it to the fan)
Fan overide works great...
There is one terminal with 2 brown wires (I figured ground but when I grounded these wires the light did not work)
Anyone know how these switches should be wired?
THanks!!!
» Hugh
» Early 71 '02
From my write up on fog lights:
There are four connections on the back of the fog light switch: “+”,”31”,”S”, “S”.
The “+” connection goes to a switched +12vdc source. This is the control that should only allow the fog lights to be on with the low beams and not with the high beams. A good source for this is the yellow wire from the high/low beam stalk switch.
I used a crimp-on 3M nylon t-tap. These allow you to use an insulated ¼” quick disconnect for the new wire.
If you wish to run high powered driving lights to be on with the high beams only; you may tap into the white wire from the stalk switch. Further more, the yellow/white wire is live whenever the low or high beams are on.
The “31” connection goes to ground. A ring terminal can be connected on the left-side mounting stud for the heater box.
The “S” connection (either one) will then go to your control relay.
Steve J
& too many bikes
