Houston we have a problem.
Armond
First the Trunk lock now this. I turn the ignition key. I have power but engine does not even crank up. battery is new....Is it the coil or Starter?
73 Tii A4 BOD Oct. 13,1972
74 Tii BOD Nov. 16,1973
FAQ Member 1683
Mario Andretti
no crank...means starter
check ground connections...tight?
check battery to stater wire
check to make sure powered wire from ignition is connected to the selonoid, also that it is getting power when the key is in "start" position
still nothing after that and you have power to the starter...both from the batterey and from the switch. Then Pull the starter and have it checked.
btw...pulling the starter is pretty quick and easy.
hth,
Jake
1985 e28 w/LS1/t56 and a bit more...
1970 2002 w/ m42 swap
-Contact me for m42 mounts or e28 ls1 mounts-
www.classicdaily.net
hth,
Jake
Does this mean removing the cables from the Battery before I remove the starter. My trunk is still not open due to lock issues
FAQ Member 1683
Mario Andretti
If the battery is in the trunk...yes
Do you have a junction block in the engine compartment?
Or if you still want to take it out...just pull the power connection from the starter...and make sure you do not ground it out. I would then tape over it or wrap it with something non conductive for some sort of safty
