all the cool kids are doing it
BLUNT
it seems like everyones doing headliners recently and i didnt want to be left out so i started mine today. granted its not glued in yet but it was a piece of cake. maybe the hard part is gluing, i dont know. but i have it in place pretty close to how i want it. i need to pull here and there a touch more to get the seams perfectly straight but it wasnt bad at all.
what did you guys use for padding on the a and b pillars??? and what glue is best.
www.BluntTech.com
FAQ Supporting Vendor
 Sales@BluntTech.com
wow thats sassy
Sorry blunt, no advice on the glue, but I just wanted to comment on the high sassy factor.
Aashish
1969 BMW 2002--I gotta finish this damn thing
1987 BMW 325is--S52 Monster
1975 Innocenti Mini 1001-- the most cost dense car ever!
1995 318ti
2004 BMW 330i ZHP
2004 Toyota Tacoma (gotta have something reliable!)--can't live without
i used 1/4 inch foam from a fabric store.....i wouldn't use spray adhesive unless you don't mind it getting on everything...get some contact cement with a small brush so you can control where you want it...
some of that cheapo, plastic chrome door edge stuff that's like $3.00 for 2 pieces in a pak works great for holding in down til the glue dries...it's flexible for those hard turns and you can cut it into whatever lengths needed
Where did you get your headliner from?
its a wool unit from seals perfect. its fucking sassy (or so i hear)
thanks guys, esty , have you had any issues with the contact cement holding up in heat? or isnt that an issue once its all clamped down with all the other crap.
im actually using pinch moulding to do the same thing you suggested with the chrome plastic stuff. works good
www.BluntTech.com
 Sales@BluntTech.com
mine sits in a metal shed everyday and it's been getting above 100 outside so i'd say it's at least 25* warmer inside and nothing ever came loose...it set just glued for 6 weeks befor i had the windshields installed and notta problem with it coming loose
Heres a dumb question,
How much glue will the wool headliner "soak up" in the process of attaching it to the pillars?
I have always wanted a wool liner but have been afraid the pillars would get crusty looking from the wool soaking up the glue and turning the material hard.
69 2002 1668997 "Geboren ein Hölle"
Shhhhhh... Another Whispering Bomb!!
i'm sure we're gonna find out from the experts but that's my experience with a wool liner i have in one of my cars....it darken'd every place the adhesive was applied and look stained...and it was installed by a pro shop
i'd assume blunt's using vinyl, like was originally used down the pillars, so if he's careful with his glue and folds, hopefully he won't have this problem
So the wool is only on the roof and the pillars are still vinyl?
i'd assume as much but we all do things differently....since the pillars are glued top to bottom, side to side, i'd never use fabric
blunt's a sharp cookie though, he'll pull it off whatever he does
i've got my fingers crossed that he doesn't stain that nice wool liner with the glue...he's only done the easiest part so far....it requires major cursing to get it glued in...ask me how i know
If you paint a light layer of contact cement on the headliner and on the area where the headliner will be attached, wait until they are tacky dry and press them together, they will hold for,effin,ever - but you get just one try!
im glad you guys brought this up. its all stuff i hadnt thought of and since they dont come with installation instructions ones left to guess on most of this stuff. ill be careful with the glue for sure.
www.BluntTech.com
 Sales@BluntTech.com
I'm reminded of Phil Hartmann's character of the sassy magazine editor on SNL
"Sprechen sie Sassy?"
Indeed-- gorgeous work there. I wish I can focus on that- but too many other powertrain issues!!
Aashish
1995 318ti
2004 BMW 330i ZHP
