What kind of turbo will fit this flange? (nt)
PSloan
Do you know if the bolt patern is perfect square, rectangle or irregular?
some T04 got square bolt patern (not perfect square, more rectangular), Toyota CT series and some Mistu as well.
Id suspect an old KKK or a T04.
Pat Allen
1985 XR4TI, 22psi ±300hp
not to be a jerk but any kind... if you have the right adapter. measure the hole pattern and get the specs of a few turbos. they will either match up or you have your adapter pattern......
Most probably a KKK as others have mentioned....
E36
Yeah - i thought about an adapter. But If i can find the kind that is supposed to fit and has the right specs I wont have to worry about it. It's just wasier that way. Plus, I think adapters look bad.
Patrick Sloan
1975 inka 2002 - 2375719
1991 325iC
2001 325i
If the manifold is from the 70's or 80's it would not be unusual if the mount were for a turbo no longer in the market like RayJay. If it's a BAE manifold it definitely fits a RayJay. Most manifolds now use the Garrett mount standards, but back in the day, there were so few turbos that there was no standard. You don't want a RayJay, the crappiest Chinese T3 knockoff will be a better choice for A/R ratio and trim.
Tony
