Anyone familiar w/the Ireland dual sidedraft cable linkage
jlandreth
kit?Mine is the cable version.There are no instructions but it appears that one cad plated bracket bolts to the underside of the rear carb.There is another piece of flat steel w/2 holes that fits the other end of the cable but I'm clueless as to what to attach it to.At first I thought it might attach to the bracket behind the brake booster but it looks like it could mount to one of the unused flanges on the bellhousing also.I'm not sure if I have to remove the carb to install that bracket but I hope not.Worst case I can call I.E.tomorrow
I mounted the lower bracket onto the wall of the pedal box using a couple of 10mm bolts. The main thing you want to keep in mind when locating it is that there is no binding of the cable that might affect pedal travel & feel. Also make sure that you are getting full throttle movement (0-100% open) once get everything set up.
HTH...
-s
Shad
'70 2002 #671 "Bimmerschmitt"
'70 2002 BADUDA aka 'Wall Art'
'72 2002 #672 Sold
'73 2002 Sold
'79 528i Daily Driver (future ETC Clone)
