still trying to figure out that wire problem with the lights
Lorfjord
so we're thinking theres a short in the rrear liscense plate light.
I went back there and re taped the wires but that didnt do anything.
did I post this already?
Where can I find an accurate wire diagram and a harness.
I checked on roadfly and they named that harness that they had used in the past, and it doesnt show up for use on 75 02s.
any suggestions?
also I could use advice on what type of tools to buy. Right now I own a leatherman and some small screwdrivers...you know computer tools.
Have you checked the light bulb sockets for corrosion or rust ? Shouldn't need a wiring diagram if you have a voltmeter, should be simple +12 V & ground on 2 wires. Measure from clean bolt into chassis as ground inside back of trunk to both wires, should get +12V on one of them. Then measure from same bolt to the other wire for resistance, should be close to 0 ohms. If either does not read correct, you've found the problem wire, now physically trace it back & check it at each connector it goes through in the wire harness up to the front of the car.
2002 owner since 1980
I would think minimum for tools would be:
1) Good set (Craftsman comes to mind) of combination wrenches from
8mm to 19mm.
2) Set of 3/8" drive sockets/rachet: same sizes as above (again, I'm
using the same set of Craftsman I've had since 1959).
3) Set of about 8 (or so) assorted screwdrivers, slotted and phillips mix.
Also try to get about one 15" slotted screwdriver - lots of things need
extra torque.
4) Used less often, but still helpful when you need 'em: 3# to 5# dead-
blow hammer, a 3# sledge hammer, and a small (1# +/-) rubber
Hammer.
5) A multi-meter (if you're just starting out you can get one that will
suffice in the $10-$20 range).
6) A ½" torque-wrench w/ a ½"-to-3/8" adapter (again, to get started,
an inexpensive one will suffice for awhile (good ones run $150 +).
7) Among my favorite tools are GearWrenches in 10mm & 13mm and
a Snap-On ratcheting screwdriver, but these can wait 'till you get
started.
Hope this helps,
Bob Napier
