Dieseling with 74 tii
Hot spots in the combustion chamber(s)? Could be excessive carbon buildup. First thing I'd do is buy a $7 can of SeaFoam and run it through the TB or a vacuum line that feeds all cylinders. Even if it doesn't solve the problem, it's a good product that cleans the engine pretty well.
It could also be a badly adjusted pump, worn linkages, a sticking warm-up regulator or a combination of any of the above.
Did you swap your distributor with a non-vacuum unit from an earlier tii?
Pierre
O==00==O
69 2002 (M20), 74 tii, 76 533i, 79 323i, 80 732i, 84 323i (S50) 91 318is, 96 318ti (S52), 97 Z3, 02 330i, 03 525iT, 02 R1150 RTP.
Auxiliary Lamp Brackets  Kamei Reproduction Front Air Dam
I already did the seafom. Though I would ASSume that hot spots would cause pre-ignition or pre-ignition induced detonation at the top end....
All good information. Not sure on the distrbutor, I know it is not the unit the manual states it should have. off the top of my head it is a 231 188 and I think 002....could be wrong though...
It's sounds like stoolpusher syndrome, did you read the responses from the last time you asked this question?
I just did a search for dieseling and I only have one post with the word dieseling.....so I am not quite sure what you mean....
As for "stoolpusher syndrome" no clue what that is.
Jonathan
normal when you park with one !
try:
ignition timing
idle speed
idle Co mixtrue
correct spark plugs and gaps
remove carbon from combustion chambers
cure over heating
valve clearance
....diesel on dude!
'64 R27 250cc #383851 18,000m
