Look Ma, No Distributor (megasquirt porn)
finkbuilt
Very nice... how much $$$ do you have into that conversion?
I may think about something similar.
I dont know. I am not doing the best accounting. The EDIS stuff was $80.00 including trigger wheel, wires, module, VR sensor and coil. (ford escort) I probably have another $600 into the ECU and fuel system which I havn't installed yet. Your biggest investment will of course be time.
73 Riviera Daily driver 2002 - MS, 9.5:1, cam, LSD
id,4943
just a thought, but you might consider moving that module there off that fenderwall, and put it back on the firewall behind the engine, basically in the centerline of the car area... thats where i put my e30 318i ignition module, as i found its a much cooler and dryer spot than that fender location... :) P.s. nice frickin job... :)
Not a bad Idea. That exhaust side of the bay gets pretty hot.
I was thinking that I might move it inside the headlight area.
inside there is too wet, i think. if anything, id move it inside car before putting it further forward... :)
