installing early 320i motor in an 02, couple questions
jerry
i have an opportunity to acquire a very fresh-looking M10 engine from a 1978 320i. the head is an E21 casting. i'm hoping to put this into a '73 02 with automatic transmission.
to keep costs down i was just going to purchase the block and head.
is there a reason to buy the distributor too?
was wondering if there's any engine-specific issues with distributors?
i suppose the flywheel/clutch would match up with the 74-76 model 02's IIRC.
the intake manifold is the tii-looking type. any reason to acquire it?
& 1 special alfa
make sure that the 320i distributor drive gear is identical to the 2002 and not a mirror image that drives the opposite direction
the 76-79 e21 distributors have the same rotation as the '02. FYI and IMHO the mechanical advance dist works really well on that motor.
Cris
Proud member #113
The rides!
www.cardomain.com/ride/792851
www.cardomain.com/ride/792793
thanks guys. i was a bit fuzzy on that issue and only vaguely recalled previous discussion on the subject of dizzies.
while perusing the archives i noticed that the stock E21 equiped engines used flat top pistons resulting in lower CR. was this for some sort of fuel octane or emission reason?
& 1 special alfa
the fuel pump boss (undrilled)
and the oil pump and oil pan.
And yes, use the later throwout bearing, and the clutch is the same.
Should be easy!
Auto trans means you're going to need to use all of your own stuff from the R.M. Seal back, torque converter, etc.
E36
