Valve cover strip/finish....
I just finished my valve cover mods for my race car on an old valve cover a board member sent me.
I wanted to get it sand blasted and the local sandblaster only has fine silica and he said it would probably pitt the soft alum. valve cover so much it would look rough....
what should I do?
take sand paper to it........talk about a bummer....going take for ever....
Maybe I'll just spray it with a krinkle finish balck paint.....
which krinkle finish do you guys recomend?
how have you finished you valve cover? post pics and process
THANKS!!!!!!
68' 1602
98' ///M3 Sedan
88' ///M3 Sold *
06' ///M3 Competition Pkg Sold *
http://www.bmw1602.com/
with glass beads, but if you can't black krinkle looks good too.
Prep is the key, clean, clean and reclean. VHT is very good stuff, and a warm bbq grill helps the krinkling go faster.
1972 2000tii Touring #3422489
FAQ member #5
i've sandblasted most underhood parts without ill effects, including several valve covers...unless the dude lights a smoke while holding the loaded nozzle in one spot, it's unlikely even a novice would damage a valve cover
it's the best and most effective way to thouroughly clean the parts because the aluminum parts are somewhat porous & like to hang on to old crud and slime
If you can get it to 200 degrees for 5 minutes or so, after you clean as well as you can, more moil will surface and you need to clean that too.
Sometimes I pre cook for two or three times before I powder coat
FAQ member #5
I've been sucessful using paint stripper to get oil paint off. I've then sprayed a ton of brake clean on the cover to "pull" the oil out and wipe it down with paper towels. I've found that the Eastwood's wrinkle coat seems to work the best. I usually warm up the cover with a halogen lamp before shooting. If it doesn't start to "work" within 5 minutes, I shoot another heavy coat and help it wrinkle using a hair dryer.
Bob
3410619 - 74 1802 Verona Touring
3460120 - 74 Verona Touring....... (Sold) sent off to LA.
2760306 - Ultimate driving machine Skidmark 204 car. 72 Inka (Sold)
Formerly the old and slow division of Skidmark Racing.
go ahead and sandblast that cover. i've done it up to 70psi without problem. it will give it a matte finish. you can then easily burnish it with 000 fine steel wool or spray paint it with dull aluminum for a factory fresh look.
photos, please...
photos, please...
photos are on the way....
68' 1602
98' ///M3 Sedan
88' ///M3 Sold *
