Any gotchas mating a 73 engine to a 69 6 volt? (nt)
Mars
I would think that should work fine. I would assume the 6v coil would generate the same amount of power to the spark plugs as the 12v coil and I think the temp sender and oil pressure sender can work on either 6v or 12v so you should be fine. Just be sure to use the 6v alternator which I believe is different. The starter maybe different as well...
'03 BMW Z4 3.0i
’89 BMW 325is
'80 Mercedes-Benz 300SD
'20 GMC Sierra 1500 SLT
