head gasket woes....stock gasket or MLS
jakeb
Alright...so I am going to give this another go. Checked flatness of block and head...check...check.
Cleaning out the bolt holes and making sure the surfances are very very clean.
So should I use this fancy MLS cometic gasket that I have or use a stock head gasket?
Speaking to both ireland and cometic they suggested copper spray on the cometic to help it seal everything up.
I am going to put it back together tomorrow morning...or that is the plan. But would like to know which gasket I should use..... fancy cometic or stock victor/reinz
This engine in time will be boosted...the reason for the cometic MLS gasket.
any help would be appreciated.....
1985 e28 w/LS1/t56 and a bit more...
1970 2002 w/ m42 swap
-Contact me for m42 mounts or e28 ls1 mounts-
www.classicdaily.net
...a 'factory' BMW, Mercedes-Benz, or SAAB head gasket
has 'sealent' impregnated in the gasket material -
come packaged in air tight package to preserve it, and should never have
additional goops applied to them. Only in some cases a tiny dab of silicone
sealent where timing cover gaps meet . So if one of your gaskets is dry and the other one tacky to the touch - I'd go with the tacky feeling material.
dats just my 35+year $20.02 wurth
'64 R27 250cc #383851 18,000m
I've been impressed with the stock- ish Reinz gasket-
if you torque it per the instructions, I've found NO blowing or leakage.
