Wanted- Picks of 74-76 grills painted to look early
aaronr
As some of you may have read in my previous posts, the PO of my car added a 74-76 front clip to try and get better air flow. I want to change it back, but it appears to be a huge project. It was suggested that I paint the late grill silver with the appropriate slats left black to give me an earlier look.
Does anyone have pics of anything like this?
1972 2002
i used, including the ones i wasted ( i probably wasted more than i actually used getting the hang of things) approx 4 sheets...i'm doing a pair now, using the rolled metal foil tape...it's a lot easier and you can do one slat with a single strip...the rolled metal foil tape isn't as fragile, much easier to work with & it's a lot easier to find...home depot sells it....
if i'm able to find time before my minds wanders to something else, i'll try to finish one and post a pic of it as well
How do you deal with wrinkles in the tape? That tape is so sticky, I can't imagine it going on without wrinkles. Very tedious looking work. Nice job!
Also, how do you clean the grills of years of armor-all from previous owners?
I've always wanted to try making the late grills look like the '73 grills.
'76 2002 (Sold)
2002 Subaru WRX Wagon (at least it's a 2002)
it is extremely hard to lay down without wrinkling...i started it and tried to keep it off the piece as i laid it in place by keeping a piece of wax'd paper in front of it as i burnished it with the backside of a spoon as i went along...
it takes a lot of patience and practice but once you get a routine down, it'll speed up...
i find, for me, the best cleaner is wesley's bleach white (found any place, wal-mart, autozone, etc that sells auto cleaners)...i place things in a container...i use one of the larger plastic storage type boxes, then spray them down. allow them to sit a few minutes, then rinse well and wipe down with automotive wax remover...the stuff used as the last step to clean a car before painting
BTW, the light surround, the round part is a B**** to do...you have to do some creative splicing with a lot of small pieces in a few spots and those are where you'll waste the most material
here's one i started but forgot i have...it's painted...
i started by cleaning it as mention'd above, then scuffing it with one of those BBQ cleaner, scrubby things...wiped with wax and grease remover then painted...
i started by priming then painting the entire gill with the paint pictured...
i prefer dark gray instead of black....i used silver metallic model paint, the stuff in the tiny bottles with a flat tip'd brush
