I've have a dual tip Scorpion muffler on my Tii installed by the PO. I have ansa headers and would like to replace this obnoxious muffler to something more semi conservative. Suggestions will be much appreciated. thanks
73 Tii A4 BOD Oct. 13,1972
74 Tii BOD Nov. 16,1973
FAQ Member 1683
Mario Andretti
You could do a stock muffler, turbo muffler or an ansa sport... I find the ansa sport loud. Magnaflow's are ok too apparently
People here have also vouched for the Ireland kit which uses a Magnaflow center resonator and a Dynomax muffler.
1963 Vespa VNB
1972 BMW 2002 - Sold :-(
1972 Porsche 911T - Sold :-(
yes... just put the ireland kit on (it is now two magnaflows- a 4" and 6" aluminized)... not loud or droning at all... very close to my old stock setup only a bit more throaty (nice)... noticable breathing difference... looks and fits good... very pleased.
Rob
1966 Mustang vert - 5.0EFI/AOD & mods
1975 '02 - the typical upgrades (my 'new' car)
Thanks Gentelmen! Called BMP and they suggested splicing in a glasspack. I'll have to go to a muffler place and check that one out. I'll also check in into the Ireland engineering set up. thanks
FAQ Member 1683
Mario Andretti
you could try that first.... because the scorpion is suppose to be a good muffler... get a 4"round magnaflow or equal muffler say about 16-18" long (can't remember all the sizes available... but too long like a +20" might be difficult to fit).... have them place it as forward as possible and see if that mellows it out. If it's not good enough replace the scorpion with the 6" magnaflow and you have the ireland set up... by the way... what ireland sells them for is very good... just get the kit and try it one piece at a time. If you don't need the 6" it won't be a huge loss... could probably even sell it through this forum. If it's still too loud for you... you realize the headers will probably have to go?
Rob
Rob,
Thanks for your imput. Got the car on a lift and here is what we found.
1-3/4" pipe. 36" resonator and a freeflow muffler with dual resonator tips. The shop guy said 1, there is no room for a glasspack 2, he siad that we should remove the Scorpion muffelr and slap in a Ansa # BW0207 w/c is a stock muffler. I don't mind doing the Ireland engineering set up but will there be a whole lot of difference? Thanks
FAQ Member 1683
Mario Andretti
