If your car is mainly stock then keep the stock manifold and dump the ideal of a tii manifold.
there has been several test that have concluded that there is no advantage of a stock manifold versus a TII especially when all things are equal.
If your modified then you will be dollars ahead getting a header.
I would stay with a stock manifold or move up to a header.
2002 cars are really corked up and need to breath.
If you ever measures the diameters of the ports on a stock a tii together there is not that much of a difference that your car is gonna make 10 hp more than your neighbors without a tii manifold.
In order to make power you need to flow and a tii does not flow as much as everybody thinks.
have access to a cylinder head flow bench numbers do not lie. .Sounds like your on a skimpy budget trying to get as much power as you can for cheap.
Stay stock or drop for a header a 4 into 1 for max power and a tri-y for strong midrange.
If your gonna make at least to 150 HP then 1 5/8" straight is best .
no step this is garbage marketing material.
If your TOP Fuel NHRA 6000hp motor and you need to dump faster than you intake then get a step header
If not.Toss that ideal
no 1 1/2"
no 1 3/8".
This is just my 02 cents
Good Luck
