It all depends on how wide the wheel is! A 6 in. wheel with a 3 in. backspace would have 0 offset. A 7 in wheel with a 3 in. backspace would have a +1 inch offset. Offset is the distance from wheel center either positive or negative. Get it? Once you have the inches, you need to convert to MM since that is usually the standard for offset.
so a 5 1/2 inch wide wheel with the 2 3/4 backspace would make a zero offset correct?
Correct (5.5" /2=2.75") What wheel have you found and are trying to fit?
Beaner7102
Some people include the rim thickness and lip when measuring backspacing, so find out if that is the case here. That can add 1/4 to 1/2 inch to the backspacing.
Curt Ingraham
1972 2002tii, 1976 2002
Improved 2002 Radiators
