Hi all,
I have recently noticed a "clunking" noise coming from the front subframe of the car when I go over a bump. My urethane bushings are six months old or so so I dont think thats the problem. I believe the problem lies within my calipers because the sound lessens when I hold the brakes, but still doesnt go away completely. I was told to try getting new brake pad retaining pins et al, but I still feel like the problem goes deeper. Any thoughts?
the reason the clunking goes away with the brakes on is because your keeping a load and pressure on the front of the car when braking. you need to lift you car and support it on stands. Check all the ball joints, sway bar links and shocks (loose collor!!!). to check the ball joints swqueeze them with a large 12" or LARGER 16" is prefered channel lock plyers. these can also be used to check the lock collors on the strut tubes.
sam
LaValle's Import Restorations
Oak Ridge, NC
Thanks for the tips. I will give that a whirl. Also, what are channel lock pliers? I may have them but call them something else. Any photos?
is the sequence of washers and spacers at the top of the shocks. That sequence has been posted here before. I think it was a scanned pic from McCartneys restoration book.
My e21 had new shocks installed many years ago and the mechanic either left out a washer or got them in the wrong order. Drove me crazy until I straightened it out.
1972 2000tii Touring #3422489
FAQ member #5
I knew I had some of those pliers. Now how exactly do I tell if it is clunking? By feeling the ball joint? I am a little confused.
if the brakes aid in eliminating the clunk - loading the chassis -
look at the front thrust arm bushings and tightness - the ones
at the very front of the car next to the tow-hooks
how's yer steering box mounting (on the subframe) arm ? cracked or worse?
'64 R27 250cc #383851 18,000m
