hey guys. had to remove the stabilizer to get the alternator out the other day. Looking at the bushings, the round ones located on either end of the bar look alright, but the two half circle bushings that are more inward on the bar aren't as good. I am wondering if there is anyplace I can order just these bushings. BavAuto just sells sets. Also, is it alright just to replace thse two, or do you recommend replacing them all? thanks
Ryan
Yes, and here are the part numbers:
front: 31 35 4 454 010
rear: 33 55 1 103 492
Looks like list price is under $5 each.
If you have bigger aftermarket bars, you will probably have to buy a whole set.
BMWCCA #2762
72 2002/71 2002ti, 67 2000CS, 2x 72 3.0CS
86 635, 2x 05 330Ci ZHP,
'11 Corvette Grand Sport
I have found that a common kerf cut to the stock busings will accomodate bigger bars. Obviously, the bushings will be rendered somewhat useless if you ever plan on reinstalling the smaller diameter bar.
what size is the stock bar? pretty sure mine is stock, but as I just got the car, I'd like to measure and make sure. mine doesnt look too beefy, so it's probably the stocker.
Ryan
