I'm sure both items have been discuss at nausium(sp.) but opinions on:
1.Dino vs.Synthetic oil on my 72 tii.
2.Redline waterwetter.
I've used both for years with British and watercooler V.W.s with good results
thanks
jgmgti
1973 Malaga "ti"2.3 stroker,dual 45s,lots of Alpina content13x6 Superlites bilsteins,Petri Sport ,GTS Seats,Coco Mats,Old Man Style "Patina"....but the old Emily is Fast.
2010 GTI 200 H.P.,dsg ,18"wheels etc.modern daily driver.
I changed to Mobil 1 15W-50 after the head work, and run Water Wetter in the E30 & E28. Temp has been fine in the tii with Curt's 3-row radiator, so I haven't used it in there.
There's no problem changing from dino to synthetic anytime - benefits at start-up - but, because it flows so well, a small oil leak MAY become a larger leak!
John in VA
Thanks John,I have used synth. oil for many years but had some concern about the k-fisch pump and synth.oil.So far no cooling issues, but a little lower is always nice in the heat.
jgmgti
hey jonathan,
i'd say that if you just rebuilt the engine, there are no problems using synth. otherwise, for a higher mileage engine, just stick with good dino oil. i use castrol 20w-50 in mine and change every 3k. it's cheap insurance. also, carl nelson sells the mahle/mann oil filters at bimmerdoc.com for a good price as well. i get mine through CDOC's worldpac account...just bought 10 of them, so i should be good for a while!
btw, got your message last night. we're getting ready for a weekend party, so we were out late buying beer and bbq fixins. i'll give you a buzz tonite when we get home.
brad.
'74 turkis 2002ti(-i)
Thanks Brad,I'm the type of guy who over maintains,changing synth every 3K,I know thats nuts...w/ oem filters. My motor was rebuilt around 14k ago, so its still on the fresh side.My concern was w/ the K-fisch pump more than anything.
Speak w/ you soon.
jgmgti
oh yeah, one other thing. i've read here on the boards once or twice that the redline water wetter sometimes causes a weird, oily condition with certain kinds of coolant. not sure if it does that with the blue BMW coolant, but it might be worth doing a little experiment before adding it to your system. i've been holding off adding the bottle i have until i do a flush and refill with the good BMW blue stuff.
brad.
Brad good thought,the radiator is going to be flushed next week along with a rear-subframe rebush and resto.
jgmgti
1.Dino vs.Synthetic oil on my 72 tii. = EITHER IS o.k. - so long as your top oil weight number is 50 (15/50, 20/50)
2.Redline waterwetter. = don't bother - use BMW approved antifreeze in the correct ratio and change it every 2 to 3 years.
my $20.02 wurth
'64 R27 250cc #383851 18,000m
c.d. thanks
Made by the same folks, but at a bit of a savings. No Saab dealer around here, so I haven't checked it out.
John in VA
...how much $$ ---=G.O.O.G.L.E.=----
Thanks for your help, I tried google before I asked, too much junk and advertising to wade through. Very frustrating. I guess I will call my busy dealership though I didn't want to pull anyone away from the counter.
1963 Vespa VNB
1972 BMW 2002 - Sold :-(
1972 Porsche 911T - Sold :-(
Thanks for everybodies comments....
jgmgti
hey jonathan,
i'd say that if you just rebuilt the engine, there are no problems using synth. otherwise, for a higher mileage engine, just stick with good dino oil. i use castrol 20w-50 in mine and change every 3k. ....
brad.
I couldn't run mine with Castor 20W-50. I'd get bad smoking on deceleration after high speed, e.g. coming off an exit from the interstate. Value guide issue.
I switched to Mobile 1 synthetic and the problem completely went away.
