O.K. which bushings should I use for this upgrade?
And Can I put my ground wire to any of the bolts on the alternator?
I know this is so simple!
MZ420
1975 malaga '02
, 38/38 weber,close ratio steering box w/ urethane bush. 320iradiator,recaro,momo ,14" 320i rims
tii ex.manifold,ansa exh. H+R spr. bilstein....on..and on..
If you're refering to thesupport arm bushings they're the same as stock. My ground wire goes from the top nut on the back of the alternator to the top, inside bolt on the timing chain cover.
Bob Napier
