Can any of you guys tell me the best thermostat I should use?
I can get either the 185 degree or the 195 degree.
decisions , decisions.
MZ420
1975 malaga '02
, 38/38 weber,close ratio steering box w/ urethane bush. 320iradiator,recaro,momo ,14" 320i rims
tii ex.manifold,ansa exh. H+R spr. bilstein....on..and on..
MZ420
Depends on where you're putting the thermostat. If it is going at the bottom of the radiator (like a E21) then I believe you want the cooler one.
Matthew Cervi
'71 Bavaria
'18 M2
Yeah I thought the cooler 185' would be best. I'd rather the fan go on sooner than later!!
I'm going for a Spal 11" for the front of radiator, there isn't much room up there
Thanks for the feedback.
Moonman420
1975 malaga '02
The fan I'm getting is rated at 1300 CFM. Draws only 9 amps
The dimensions are 12.1" high X 11.5" wide. Just fits up in front of the radiator.
The blades are also curved, this is supposed to give you more CFM.
Moonman
1975 malaga '02
Not quite, curved is quieter and gives you less airflow. Most cars now come with curved for NVH reasons.
Straightblades push more CFM. My 14" is 2950CFM, you need around 1600CFM in a 4 cylinder to cool efficiently. You can probably get away with a little less depending on traffic and local conditions.
You also lose 20%-30% in a pusher configuration. Keep that in mind when choosing a fan.
-Justin
thanks for the info. Are your fans mounted in the front or rear of the radiator?
MZ420
1975 malaga '02
without drastic mechanical surgery. The space between the radiator and the water pump is very small (a centimeter or so), and it's independent of whether the mechanical fan is present.
Curt Ingraham
1972 2002tii, 1976 2002
Improved 2002 Radiators
Maybe paddle type blades would work better. They seem to give more CFM.
Thanks for all the input fellow Bimmers.
MZ420
1975 malaga '02
