Are there any other differences between tii and 2002....
Mike87
front strut housings other than caliper spacing and spindle size? Are the strut tubes the same diameter and thickness? I know that there is a bulge at the top of the tube. Are they the same?
TIA,
Mike
Good Luck,
Mike (#87)
Had this info:
Differences between the 2002tii and other 2002 models:
1972-1973 US 2002tii VINs begin with 276
1974 US 2002tii VINs begin with 278
Kugelfischer mechanical fuel injection
alternator mounted down low, under battery (diff battery tray)
oil return line in block for injection pump, feed line in oil filter head
larger 7in diam brake booster
larger 23mm diam master cylinder
larger 10.08in (256 mm) diam front brakes
larger 4-piston calipers/pads
larger front hubs and spindles/struts
larger rear drum cylinders (17mm)
boxed rear semi-trailing arms
interior clock
2002tii emblem on rear body panel
Where we goin’? … I’ll drive…
