2002 or 320i distributor
Which one to use? I'm just about the order a new schrick 292 and I can get one in either direction.
I did a search and it seems there maybe some advantage to using a 318i distributor and setup. Correct?
318i/320i dizz is electronic/solid state, and you can use the BMW/BOSCH ignition controller box that goes with it. now electronic and solid state is GOOD, but i dont know what advance curve each has built in, etc. so you will want to research that and find out what is going to match your engine the best.
I have the 320i/318i electronic ignition and it works well, but the only reason why im using it is because i *HAVE* to, since i also happen to be running the 320i engine to go with it... any custom engine setup and id want to look into the advance curve situation further. probably want to have any dizz recurved to match a custom engine setup.....
for your purposes, id stick with the "normal"-direction cam and work with the electronic options for the regular dizz, tii dizz, etc... :)
