Fuse 11 update and continuing saga
Thanks for the good tips guys.
I spent a day trying things.
Put my old mechanical fuel pump on.
No vacuum...hmmm probably why I changed it 20 years ago.
Bought a $30 generic pump and insalled it in the trunk.
It worked fine, fuse now blowing instantly.
I was chastized by by brother for not trouble shooting before doing all this.
Fuse diasgnotistic tip.
I took the fuse box off the fender, it is only one little screw and it
just lifts up to see all the wires.
I unplugged the other two wires to fuse 11 and started the car.
Electric fuel pump worked fine.
I plugged one of the wires back into fuse 11 and it did not blow.
I plugged the third wire in and the fuse blew.
Unhooked that wire and drove about 4 miles home.
I haven't had time to look in the book at where that wire goes, but as far as I can tell everything on fuse 11 is working.
More mystery when I get the time.
Please note that I turned car off and unhooked battery ground cable before every item above.
Ray,  Current BMWs, 1973 BMW 2002, Turkis, and 1997 BMW 318i 5sp avus blue.  Drove a lot and sold over the years, in reverse chron.
     1997 m3 coupe silver, 1998 318ti red, 1996 318ti red,
     1973 2002 Agave, 1971 2002  GM brown
same terminal? If so, one of those is the instruments and the other is that #@%&** seat belt warning light sensor wire I mentioned yesterday. Check your wiring diagram and snip the wire that isn't in it--or call me at home this evening and I'll look up the reference.
cheers
I found a wire that was bare from rubbing underneath the air filter housing. This must be the automatic choke wire. I had it tied back on the brake vacuum assist hose under the housing.
I cleaned that up and now no more fuses blowing.
