Looking from the top down with the choke plate off what hole do you block off according to CD's prescription, I know this was posted before but I cant find it using the search for the life of me!
Rob.
http://www.bmw2002faq.com/content/view/18/32/
If you look at the SECOND TO LAST picture via the link, there is a picture of a 32/36 with the top off.
Looking at the TOP half of the carb (which is upside down with float still attached) ) you can see a brass tube sticking out inside the as pictured left barrel (in practice it is the right side or secondary barrel).
Still looking at the top part of the carb, see where this brass tube "goes". It has a corresponding brass orifice on the surface that mates to the bottom part of the carb. This is the hole to plug.
If you look at the BOTTOM part of the carb, their should be a brass orifice that matches up with the one on the top part of the carb {it will be to the right of the right side (as pictured) air corrector jet}.
I think you can plug the hole on either the top or bottom portion of the carb.
Hopefully, CD will respond to confirm this...
