Things I've yet to do:
Top priority:
- Oil change
- Fix Passenger side door lock (install tumblers/rekey)
- Acquire and install trunk lock + rekey if necessary
- Get a window regulator for the passenger side door
Things that can wait:
- Buy a black carpet set (anybody got one for sale cheap? I need it all, floor carpet, kick panels, etc.)
- Do something about the hideous mess that was the short center console
- Buy bushings for transmission linkage
- Determine whether later spare transmission has good BW synchros
- - If it does, install it
- - If it doesn't, buy new synchros and install it
- Install VDO gauges (I have oil press., oil temp., water temp., amps, volts, and vacuum; what should I use?)
- Buy a few bulbs for the gauge pod
- Clean up and reinstall black slats for grille
Thing's I've done:
- Cleaned and installed spare wiper fluid pump
- Remove center console and horrendous wiring job
- Fix steering column cover so that the car doesn't honk when I turn right
- Fixed a few rattles in the door
- Discovered the fuel gauge didn't work the hard way and fixed it
I know I'm going to hate it at times, and my wallet will be hurting, but I'll be damned it if won't be fun.
