Anti-Roll bar ?'s
I was looking at a site with photos of some E30M3 DTM cars and like the adjustable "blade type" anti-roll bar setup these cars had. The best part is they are adjustable from inside the cockpit. Is anyting like that avaliable for the 2002? Do you adjust your front & rear swaybars or are the IE hollow bars good enough to be left alone?
TIA
  • Administrators
i think the question should be: "are you good enough to be capable of making those changes from inside the cockpit?" Most of the people won't know what to do. I have not seen any bars for 2002 that have that capability, but i am sure they can be built. There are no strange bends in the bar to prevent you from making a custom one.
steve k.
Get your 2002 FAQ merchandise from 2002FAQ Store
There is quite a bit more fabrication and thought that would need to go into this than meets the eye. There's running cables into the cockpit, figuring out the right type of material to use for the blade as the main bar does not appear to bend, only the blades themselves. Then there's the matter of reinforcing and rigging up the levers and means of adjustment. I would have thought that the GrpA cars had something like this and that it would be easier to get than to completely fabricate this.
