Will 15x7 +12 wheels fit on a 76' with turbo fenders? Will they even fit on a 76' with stock fenders or are the turbo fenders a necessity?
Driving, to me, is proof that I am alive.
planning on putting really narrow tires (like 185's) or so. Ideal for 205/50's is about ET28, these will run without flares, but you'll have to roll your fenders. Doing the simple math that makes about ET17 or so for 225/50's (but those will absolutely require flares).
ET12's would put the wheel another 5 mm (call it a 1/4") or so further outboard.
Good luck!
John N
Correct offset is ET25-28. ET12 will stick out further. So yes they will fit with turbo flares, or maybe Alpina lip flares (Dave Pineda - dapbmw sells them). definatly not stock guards - the tyre will stick out past the guard by about 1.5" with 195/50/15 tyres. Beaner7102
So as long as I have the turbo fenders, I should have clearance for 15x7 +12 all around? What size tires should I consider looking into? Im thinking about changing up the suspension too so if you guys have spring/shock and tire size combos that you know of, let me know!!
Stock tyres were 165/80/13 = 23.4" daimeter, try and pick a size that is close to the same diameter (or a fraction smaller) for example: 195/55/15 = 23.4" dia, 205/50/15 = 23.1"dia 215/50/15 = 23.5" dia. But it also depends on what is available in your prefered tread pattern. Beaner7102
...and hope you have STRONG ARMS - steering effort will
be like flintstone-mobile. have fun
'64 R27 250cc #383851 18,000m
As wheel offset gets closer to zero, steering effort is actually easier assuming the same tire.
**Formerly known a Cam_A**
-'91 318is
So as long as I have the Turbo fenders, and I'm running 15x7 +12 offset and 205/50/15 all around, I should have no problems with rubbing or fitment but should be ready to use some spacers?
make them fit. Putting flares on the front is really easy, it's a bit more involved to do the rears. Check the archives for some how-to articles.
John N
