Cannot get my turn signals (front and back) to work. They light up but do not signal. Even the hazard button does not work. Have tried two hazard switches.
Any suggestions would be greatly appreciated.
Peter CS
74 Inka (2.5 yrs and 95% complete!)
Maybe try the usual suspect. Check and clean all the applicable ground connections, starting at the turn signal lights. Also check the ends of the bulbs and the socket contacts for good connections.
Gil
73 02
are either stuck open or closed...pry the cover off the flasher and observe the points (2 sets) in action with the turn signal lever engaged and the ignition on. If the points aren't moving either the flasher unit is bad (the electromagnet that opens/closes the points isn't getting power or is shorted out) or they're stuck. You should be able to figure it out by looking...substitute a known good one--I think the e21s use the same flasher, as do the "Senior Sixes."
cheers
