Tonight I pulled off the valve cover to find this milky mess. I immediately thought cracked/warped head or bad head gasket, so I checked the coolant and it looked OK to me. I did a search and found that others experienced this and found that it was condensation. Is this too milky to be condensation? (the mark on that cam lobe was a little worrisome also)
Picture of coolant:
'74 2002tii
'00 Impreza 2.5RS
'04 Impreza WRX Wagon
I'm not sure if it's loosing coolant. I've never driven the car, it was a project that I took over from someone else. I didn't think of it only going one way...
'74 2002tii
'00 Impreza 2.5RS
Stop driving the car now. You've got "milkshake" and it will destroy the engine in short order.
You most likely have a blown head gasket and coolant is mixing with the oil.
Sorry,
Max
1. Do a compression test. If you have low or no compression on adjacent cylinders, you probably have a blown head gasket. Take Max's advice and don't drive it until you fix that. If compression is even on all four cylinders, try this...
2. drain old oil--let it drain for several hours--you might even pour some kerosene into the valve chamber--or spray it down with WD40 or the like to try and flush the water/oil mixture down into the sump before draining. You want to get as much "milkshake" out as possible. Then refill with fresh oil 9and a new filter), start it up and run it for awhile. Look for bubbles coming up in the radiator--that's usually a sign of fluid interchange between oil and water. Then shut engine down and check for milkshake condition in the valve chest again. If it's there, you have a cracked head or block, or a blown head gasket that isn't manifesting itself with a compression test.
It's just possible that before you got the car, the PO didn't use it very much and would start and run it for a few minutes, then shutting down before the engine had a chance to warm up. Thus condensation.
Hope it's the latter case...let us know what you find.
Yeah that cam is toast, I think that is to much milk shake for condensation but your going to have to pull the head to change the cam sooner rather than later, IMHO anyway.
Marty
Don't worry about the world ending today,
Hell it's already tomorrow in Australia.
Sorry,
Max
Absolutely! Additionaly, don't just let it sit like that, everything will rust up like the project car I bought with a blown head gasket. I had to use a 3lb. sledge and a quart of WD-40 to get one piston out! Drain the oil, squirt everything with WD-40 to keep rust from forming, turn it over a few times with a breaker bar on the crank pulley....then you can let it sit until you want to do something with it.
Thanks for all the replies and tips! I'll do a compression test and then promptly remove the sludge and WD-40 the engine.
'74 2002tii
'00 Impreza 2.5RS
Compression test results:
125 - #1 cylinder
120 - #2 cylinder
120 - #3 cylinder
95 - #4 cylinder
'74 2002tii
'00 Impreza 2.5RS
