thanks fo the info, but i think i would still like to upgrade a little, his suspension will be bilstein sports/HR performance with IE sways and mostly new suspension pieces, and he has an upgraded weber carb. so i want the brakes to match the performance.. does anybody know if 320i calipers fit on a 2002? i found some brembo ones for cheap.
oops, this meant to be a reply, im noob onthis type of forum. mods can delete this.
also wondering if 320i calipers would fit, i know about the volvo upgrade but...
You can fit 77 320i rotors and calipers to a 2002 strut (using an 80-82 e21 320i hub) if you machine the hat, diameter of the rotor and grind the casting where it would otherwise rub up against the hat. You also have to use the correct master cylinder. All in all, folks seem to lean towards the Volvo caliper route on non-tii struts
"E30 Calipers work on 68 02 single piston brake system" thread from Tues 4/4 @ about 12:30 pm - original post was from "Gene in NC"
Barry Allen
'69 Sunroof - sold
'82 E21 (daily driver), '82 633CSi (wife's driver) - both sold
66 Chevy Nova wagon (yard & parts hauler)
