Hi all. I just recently put a rebuilt motor in and it runs great, especially at higher RPM's. It also is idling perfectly, not to rich either (which is weird considering its a bigger carb. If anything I thought it would idle rich).
Its been about 1000 miles now and I am trying to get more out of it on the low end. Between 1,000 and 2,500 RPM's the motor isnt as responsive as I would like, especially in second gear but still noticeable in first. I have found myself riding the clutch a little longer before I drop it to get the RPM's up (This is NOT what I want to be doing). I definitely have to increase the jet size, but now sure which ones to increase! I have rebuilt a carb before, but this will be my first time jetting. Does anyone have any suggestions?
Which jets should I change? Main jets? My car's specs are listed in my sig. As for my current jetting, I have no idea. I ordered it from Peirce Manifolds here in CA and popped it on.
adjust valves COLD 0.006"
set ignition timing with TIMING LIGHT at 1400 RPM
adjust idle mixture
....this means don't touch the jets till the BASICS
are correct first. Also adjust the float level FIRST
before changing any jets. THEN find out what jet sizes
perform correctly for your climate(temp., alttitude, moisture)
Jet change is LAST
thanks to PIERCE MANIFOLDS FOR THE USE OF THEIR
WEB SITE DIAGRAMS - THEY ARE EXCELLENT PEOPLE
FOR ALL YER WEBER NEEDS.
'64 R27 250cc #383851 18,000m
I've found that if you turn the idle mixture screw clockwise a little, it takes the revs out of the top end and puts more torque down low. If the screw is too far in clockwise, it will backfire some on decel and the gears will grind a little, and if it is too far out, you have to ride the clutch some, and the rear end will shake when it's at too low RPMs. I'd mess with the carb idle mixture settings a little, at first. Not too much as you said it's running good otherwise, just small 1/4 turns at most. Right now, mine is on the other end, where it revs too much in first and the car shakes when it nears the redline. Later, when I drive it home I'm gonna turn the idle mixture screw counter-clockwise to give it more RPMs in first and even out the Torque/Backpressure/AirFuel mixture some. Good luck.
CALIBRATIONS MAY VARY DUE TO REGIONAL FUELS AND STATE OF ENGINE TUNE AND PERFORMANCE. POOR RUNNING QUALITY DOES NOT MEAN A DEFECT IN THE CARBURETOR. AN ADVANTAGE OF THE WEBER CARBURETOR IS ITS EASE OF ADJUSTMENT AND TUNING.
SET UP ADJUSTMENTS
Start set up by confirming carb base line settings. Do not depend on the factory delivered settings. Check them before the carb is installed.
All settings are done with choke disengaged or warmed up so that the choke is fully opened and disengaged. This is done on automatic choke carburetors by first opening the choke butterfly by hand and inserting a wood block or wedge of some kind to hold open while the linkage is cycled (linkage operated through its full movement ) to clear the choke cam. (You will hear a metallic click as the cam is released. You can check the fast Idle screw under the choke assembly to confirm that it is not in contact with the choke fast idle cam.)
Set the Idle stop screw (speed screw see fig 1) by backing out the Idle speed screw until it is not in contact with the throttle stop lever. Cycle the linkage again to be sure that the linkage comes to close without any assistance. (Checking for linkage bind) Now bring screw back into contact with the lever and continue to open or screwing in 1 turn no more than 11/2 turns.
Set the mixture screw (see Fig 1) by first screwing in until the screw stops, bottoms out. DO NOT FORCE OR BIND AS THIS WILL CAUSE DAMAGE TO THE SCREW AND IT’S SEAT IN THE BODY OF CARBURETOR. Back out the screw 2 full turns.
TUNING
BE SURE TO FOLLOW THE NEXT INSTRUCTIONS IN THE PROPER SEQUENCE, DEVIATION WILL CAUSE THE CARBURETOR TO NOT FUNCTION TO ITS IDEAL SPECIFICATIONS AND MAY NOT PROVIDE THE PERFORMANCE AND FUEL ECONOMY AS DESIGNED.
4a. Start the engine, the engine will run very slowly more like a tractor. As long as the engine stays running idle speed is not important at this point.
4b. The first thing to do is not set up the idle speed, but to set the Idle mixture screw to lean best idle setting. First, turn in the mixture screw until the engine dies or runs worse, then back out the screw (recommend turning ¼ to ½ turn at a time). The engine should pick up speed and begin to smooth out. Back out ½ turn more, or until the screw does nothing or runs worse then turn back to the point where it ran its best.
Use your ear, not a scope or tuning instruments at this point. You want to tune the engine by sound. Adjust to best, fastest and smoothest running point.
4c. Now that the mixture screw is at its best running location, you can adjust the Idle speed the screw. The screw will be sensitive and should only take ¼ to ½ turns to achieve the idle speed you like.
Check and set idle to your driving preference. Put the car in gear and apply slight load, (AC on) and set the Idle as you like it. Don’t set it too high, as this will cause causes excessive clutch and brake wear. The Idle only needs to be 7 to 900 RPM with light load or AC on.
5. Recheck timing and vacuum hook ups. Recheck mixture screw to lean best idle again. If all is still best and smoothest idle then confirm and note the final settings. To confirm settings with the engine running. Start by screwing in the mixture screw and count the number of turns it takes to bottom out and note if the engine dies. If Idle Mixture screws are with in ½ turn of base line setting then all is well and have fun. Also check the speed screw and note how many total turns from initial contact. You may have opened (turned in) the speed screw. Your final setting should be under 2 full turns. Reset the screws (back in) to the best final settings (Per your notes) and go on a test drive and have fun. If the settings are other than described then you may want to recalibrate the Idle circuit (low speed circuit) to your engines needs. This is done by following the rule of thumb BELOW.
Simple Rules for low speed calibration
If the mixture screw is more than 2 1/2 turns out turns then the Idle jet is too lean (too Small). When the mixture screw is less than 11/2 then the Idle jet is too rich (too large). These assumptions are based on the fact that the speed screw setting is not opened more than 11/2 turns. If the speed screw has to be opened 2 or more turns then this is also an indication of a lean condition usually requiring greater change. At times it may appear to be showing signs of richness or flooding it is really a lean condition. See pictures and notes in the tech 2 article supplied in the kit instructions, view and please understand the need to keep throttle plate as near to closed as possible so as not to prematurely expose the transition holes. This is what causes the visible rich condition, and confirms the need to increase the jet size.
EXAMPLE: With the speed screw set at no more than (1 1/2) turns in after contact with the stop lever; and the best idle occurring with the mixture screw set at 3 turns from bottom, indicates the need for a larger Idle jet. Achieving the best idle at under 2 turns indicates the need for a smaller idle jet.
The secret to understanding the critical nature of the carburetor set up and the advantages of a WEBER over other carburetors is the Idle circuit. Referred to as the low speed circuit by Weber, this circuit is responsible for 80% of the driving operation. This is the reason that the Weber should give a fuel economy improvement over most factory carbs along with significant performance gains. In the worst case you should not see a significant fuel economy loss over stock, while improving HP & Drivability.
Thanks for all the help. I recently, at 500 miles, retorqued my head bolts and cold set all my valves to .006's. I know that area is in order. My timing is perfect, with a good amount of advance. (I still have a dieseling problem once and a while, but I am working on that fix now as you can tell).
I will definitely work with the idle mixture as many of you have suggested, then onto the jets if need be. C.D., what does the float have to do with jetting/idling/running? I have seen you and others mention this before but I still cannot figure it out.
Also, any thoughts either way on adding and idle solenoid? I want to combat this dieseling problem in as many ways as possible.
DESPITE WHAT THE JET SIZES ARE - the float level,
too high will cause fuel over flowing and richer running
and too low will cause leaner running and fuel starvation at high engine loads (prolong full throttle and very high speeds)
- float level first - then don't change it during any later jet changes.
It takes a dyno or portable exhaust tester to read the air/fuel mixtures
to relise the small richer/leaner effect that float level change causes.
Trust Me. The fuel level in the float bowl effects the emoltion tubes
and all the tiny holes in the tubes. So all you folks running around with
varing jet sizes and persistant poor mixtures - go back to FLOAT LEVEL ,
TIMING, AND IDLE MIXTURE BEFORE going JET Wild .
