I am at the point of changing out my bus steering wheel in my 73 2002. I have a 320 sport wheel. I have tried the bayarea website with no luck. could someone please post or send me directions. Thanks in advance.
From memory...
Remove the plastic piece from the bottom of the 320 wheel that includes the turn signal cancel arm.
Remove the horn ring. Easiest to drill out the plastic clips holding it in rather than trying to pry the clips and work them back through.
In one of the 3 holes left behind after removing the horn ring, insert the plastic socket for the 2002 horn plunger. I used a little permatex to keep it in place.
You'll likely have to sand the plastic cover that hides the wheel's hub so it doesn't rub on the column. Test fit, sand, test, sand, etc, etc...
Now enjoy your faster car...;)
