a couple of steering and suspension questions
My 2002 is pulling right somewhat hard, any thoughts? tie rods possibly?
Also, it seems to be leaning to the back left end. Not sure if the suspension needs work or what.
You can check the rear suspension pretty easy, just put weight on either side of the rear of the car, then release - if the car bounces a few time before leveling, your strut is stuffed.
If it levels without bouncing it is OK, maybe you have soft springs and the previous owner or you dont drive with passengers often to even out the weight load and the drivers side has permanently sagged.
Hope this helps.
Todd
Pulling under braking or just driving? Under braking - stuck calliper, dead rubber brake line. Just driving - stuck calliper or tierod.
(nt)
My 2002 is pulling right somewhat hard ? =
seized brake caliper pistons, bad brake fluid hoses(swollen internal),
bent suspension
Also, it seems to be leaning to the back left end?= broken spring,
worn out spring, missing rubber spacer, rotten control arm/bent,
rotten rear subframe /bent
...have you looked uder the car lately?
'64 R27 250cc #383851 18,000m
